Builds rocks and rolls (1 Viewer)
Looking good! KOH motivated me to get moving on some stuff, Those Cruisers you posted are Bad ass!
its rare to see someone use the correct tool for setting knuckle preload! ;)
Wow, turning out nicely.....
Whats the odds of you catching a picture of Rustynailjustins rig near the middle with the tire mounted up high.
good eye radd cruiser. I got to talk to him as well as drool over his rig. Supper cool guy.
Full frame FJ40 finished KOH.
Full frame FJ40 finished KOH. Rustynailjustins is selling his rig.
Met him at Pismo a few years back, asked for a ride and he replied "just take it out". Although very kind to offer I did not, great guy.
Hi jack over, great build.
Rob
Actually I was referring to this rig.. Yours is nice too :D
Oppsss. This rig is nice. Perfect lines. I was in such a hurry to get to the back door during LCQ KOH I didnt study this rig as well as I should have. Anyone know whos rig this is??
I do like how you shaped your rear fender cuts. Should give lots of clearance. I am going to be pushing my rear axle back a ways with 37's or 39's so I will need to do lots of cutting. I like how he had welded in that tube for strength. Plus it just looks good!
Oppsss. This rig is nice. Perfect lines. I was in such a hurry to get to the back door during KOH I didnt study this rig as well as I should have. Anyone know whos rig this is??
Got the set up kit from a local Toyota dealership a while ago. It helps to have Toyota motor corp headquarters down the street
That knuckle setup kit is really awesome!! Where'd you get your hands on th.;at?
didn't get much done this last weekend.
Picture of homemade 6 shooters
the stupid bolt in the middle close to the trunion was an attempt at a built in bearing/steering arm removal system.
spent most of the weekend cleaning the shop and making room for the truck. It took about 6 hours. Got rid of a lot of crap nearly a full dumpster bin full.
Now that the truck doesn't have to move I can start working on the front 3 link/panhard
went to the metal store and spent more money than I would ever want to
2" OD quarter wall for 3 link, 1.5" OD quarter wall for the panhard and 1.5 OD 120 wall for the steering extensions.
expensive
Forgot the camera on this operation but took a couple pics of the finished product.
I had to add 8 inches on the drag link and 4 inches on tie rod ao it was buy new tub and run single sheer heims or find a right and left hand 7/8 18 tap for the GM tie rod ends which was about 150 bones for the left.
So I decided to machine a filler piece for both and welded it together, then sleeved them with 1.5 OD 120 wall. rosette welds to keep in place and couple of roll pins for security.
machined down the welds. machined two lines on the left side
runnin r/h threads on both ends isn't the end of the world... if you need to adjust, just loosen the nuts a turn and run the steering wheel back and forth and it pops 1 ton tres no problem.
