@IndroCruise, do you know if the location and shape of membrane in picture is accurate in a good globe?
Good question
@BullElk!
Short answer: It is not known whether the picture attached to Post #205 above represents the membrane position in a good ‘globe’.
Long Answer: It seems likely that cutting process involved making the cutaway would have had a tearing effect on the rubber-resin-rubber sandwich which makes up the membrane. Nevertheless, I think the membrane in the cutaway is in its natural, as-manufactured position,
without the effects of nitrogen gas on one side and AHC Fluid on the other side.
The position shown in the cutaway is similar to the position shown in the diagrams in the FSM.
I have a set of old ‘globes’ – two Front and two Rear – so I measured them this morning and marked-up the measurements of their membrane positions on the FSM diagram below.
However, the marked-up diagram is illusory because, while the measurements are accurate, the measurements on the amended diagram are not to scale and do not show the distended membrane position accurately, as caused by the residual nitrogen gas. So this exercise really does not tell us much.
The old ‘globes’ came off my vehicle when the HI/LO Test showed 8 graduations. Even though the FSM says that this is the change-point for Australian vehicles (versus 7 graduations elsewhere), I could have left the ‘globes’ in place for longer. However, we were preparing for a long trip of ~6,500 kilometres (~4,000 miles), some of it along hot, rough, remote roads and trails across Australia while heavily loaded -- and so I decided on a precautionary early change-out of ‘globes’. We had a great trip without any mechanical dramas – but that is another story.
The point is that the old ‘globes’ still have considerable nitrogen pressure. The membranes in all my old ‘globes’ are visibly and measurably pushed way towards the fluid entry by this pressure. I would have to release the nitrogen pressure to see how the membrane position really compared with the cutaway picture. For now, I guess I will keep them 'as is' as a back-up set of ‘globes’!!
View looking into fluid entry of old 'globe' showing distended membrane pushed forward by residual nitrogen pressure. It is likely that new 'globes' would look very similar out of the box.
