Start with a free and fast adjustment of the front torsion bars. Increasing the pre-load on the fronts normally removes some pressure from the rear as well. You're WAY over spec in the front, so you'll have a lot of turning ahead of you.I need to attend to my AHC pretty soon too. Thought I'd play with my TYT II a little and see what it will scan/read on the AHC since I didn't want to fool with techstream. It showed a code (pump pressure out of spec). Then I was able to access my pressure readings and not surprisingly I am a bit out of whack. So I need to order new rear springs, new globes all around and go to work.....I suppose.
I apologize for the poor photos (glare on the screen), the sun was shining right into the vehicle. View attachment 2578759
