Hi All,
Just to share some new found knowledge...
After driving around with bone jarring suspension for a few months, I finally got round to fixing it yesterday. The sudden tailtale drop in AHC fluid reservoir level told me the globes had finally (after 320,000km) gone. So I ordered some more on ebay.co.uk (searched under seller 'kjs500'), he charges less for all four than Toyota want for a single one. They are actually tweaked 'Lizarte' unit.
Proceedure was simple:
1) drop vechicle to 'lo' suspension setting & switch of ignition.
2) release pressure with tube and 10mm spanner on all 4 actuators, and re-tighten. (vehicle drops slightly)
3) unscrew old globes with a ground down (7mm wide) 36mm open-end spanner.
4) lubricate O-rings on new units (with AHC fluid) and screw on, tension with strap-wrench around globe.
5) overfill (well over max) AHC reservoir. then start engine, and watch suspension re-adjust.
6) bleed the 4 actuators (as per step 2). whilst ensuring reservoir level does not drop below 'min', and starting engine to re-pressuring occasionally.
My only issue was having to remove a single running-board bracket on each side to create clearance to unscrew the front globes. And since the aftermarket globes are slightly longer I chose to grind the running-board brackets to give more room.
See attached photos for:
- tools used
- strap wrench in use to tighten new globe
- ground running-board bracket to create more room.
Total time used was around 4 hours. Probably an hour less next time. Ride is now hugely improved - I'd forgotten how 'magic carpet' like the LC100 was
/pete
- tools used
/pete
