Well, we are in the next step in replacing the axle seal. You guys have been very helpful. Lots of talk about using the BFH and heat on the TRE. Others have talked about OTC Tools and pickle forks. The question is:
Do the OTC tools work? Am I using them correctly? My son is working on this project and is needing some help. We have looked closely at "Coolerman's" excellent step-by-step on the knuckle rebuild along with "MerlinRidesAgain." Have not seen posts with the actual use of the OTC tools. Here is a suggestion by
https://forum.ih8mud.com/40-55-series-tech/253282-tie-rod-end-removal-tips-2.html
and the overwhelming winner was the BFH and the picklfork. Well, Amazon had the OTC bunch on sale for $97 for 5 OTC pullers. Did I swallow hook, line , and sinker?
My son posted in:
https://forum.ih8mud.com/40-55-series-tech/753023-removal-factory-hubs-1975-fj55-free-locked-2.html
"We have continued farther into the axle. Now we have removed the cotter pin from the castle nut, but when first applying pressure with the tie rod separator we were seeing no movement in the rod and wanted to make sure we were doing this right. One question we had, was if we needed to first unbolt the 4 screws from the top of the knuckle? As that would then be free to move when we use the tie-rod separator. If it is possible to keep on the 4 bolts that would be preferred at this moment. If not we will proceed that way. Anyways, we were hoping to get some input on how people went at this, not wanting to do something that would wreck the system as we didn't seem movement when we first put on the tie-rod separator.
Also, with the bottom two pictures, we believe that there should be a rubber ring along the tie-rod separator that has deteriorated, would that be a problem with the approach we have taken so far?
And it also looks like there is a silicon sealant in the gaskets, but don't believe that is is supposed to be done this way? But thought we would ask and see if anyone had insight on this area, and if we are going to need to replace it with this or with new gaskets and seals to the trick? We weren't expecting this so thought we would ask and see what others have encountered."
With the following "eye candy." The next post provides more pictures. I think I need a new TRE or can I get these rebuilt. If not, who has a good product -- keeping in mind I need seals and/or bearings for the knuckle:
My son posted in:
