recommend me a nailer combo...
Eagle, ID
I am in need of a framing and finish nailer combo, preferably with a pancake or twin stack compressor for home projects. I have a large oil-less compressor in the shop, but it's a PITA to move around. What do you recommend and why? Who's got the best bang for the buck?? Are these combos worth a crap? Thanks!
Costco has this combo: http://www.costco.com/Browse/Produc...=1&Ntx=mode+matchallpartial&Nty=1&topnav=&s=1
and HD has this, which I'd have to add a framing gun to, but it's got everything else I'd ever probably need: http://www.homedepot.com/webapp/wcs...langId=-1&catalogId=10053&productId=100497649
CH and Porter Cable are not in the same league. I have many PC tools and they do very well, with some nice features.
HD usually has other combos, try to find one with a framing nailer. That PC combo includes an upholstery stapler (shoots staples similar to your desk stapler, good for fabric and insulation) and a micro-pin nailer which I've never had a use for, but you might be doing small work that requires it. In which case that would be a nice set, like you said add a framer to it.
-Spike
-Spike
So Porter Cable is the TLC, and CH is the J33p of the construction arena? One of my buddies loaned me a Senco stapler to hang the OSB sheeting on my shop that was pretty sweet.....1 3/4" staples. :eek:
I'd rate Senco above PC, but CH is definitely down there. :D PC is nice for the hobbyist or professional that doesn't use the tool every day all day. Maybe it could be considered the 4Runner. They have some additional features not found on commercial tools, and are built well. Senco is generally commercial grade, meant to be used every day all day- and the cost reflects this. I'm a handyman/carpenter by trade, and have never had a PC tool fail. If I were a framer, I'd own a Senco framing nailer.
-Spike
Hey, can I get in on this? I've got an ancient compressor, but I've been thinking about getting a pin/finish nailer. How much pressure do you need to run air tools, or does it depend on the tool?
edit: just followed your link to HD. Looks like 135 to 150 psi is needed?
The framing gun and staple gun I was using this past weekend both said something like 75-120 psi. :cheers:
Thanks. Now to see if my compressor will reach that :doh:.
I used the Bostitch combo kit (3 guns + pancake) and found they worked great. Pressure used varied from 50 for the small stuff to 80 for framing nails. I bought the kit for the same reason you are looking (attic remodel) - something like $200 on sale a few months ago.
Isn't Bostitch made by Stanley or vice versa? Regardless do you have a link?
Ive got a couple different sizes of the Bostich/Stanley guns and have never had any problems. Also have a Paslode framing gun that I often prefer to use given no air hose to drag around. Runs off gas cartriges with rechargeable battery for ignition - generally works well but sometimes doesn't quite have the oomph to drive all the way into harder woods.
I love Senco nailers.
They are the best out there IMO.
i think with a combo your gonna make a sacrifice one either end,,,, thats why they are priced well. me personally i run a senco framing nailer a bostich finish nailer and a side by side comp, nothing wrong with pancake but the side by side fits in my truckbox.
Out of curiosity which do you like better?
I have used both and prefer Senco to all others.
I have run both senco framing and finishing nailers and they are heads above everything else.
Nearly never a jam with the senco guns..
my experience as well.
don't know about where you are but they are hard to find around here.
I got some old ones that I scored out of luck and love em.:D
quality...................
ive had a few different framing nailers over the years and the senco is by far the best and lightest i have used,,, its a keeper. i have only ever had bostich for finish,,, back in the day when i started working they were considered the best. mine is 20 yrs old now and i havent had a reason to replace it,,,, i have tried a few other brands from other workers and buddies on jobs, the newer stuff is lighter but doesnt seem any better performance wise.
BTW when i'm doing small jobs i use a little 5# bottle instead of dragging out the comp, works great.
Thanks for all the input. I'm thinking Porter Cable should be more than adequate for all my needs as a homeowner. Redoing decks, roofing, finish nailing, building stuff for the kids, etc! Thanks a bunch!!!:cheers:
injun..... giver.....................:flipoff2:
twas humor .................
get it.
