Build Rebuilding a 40 but no longer in a 1 car garage.
Dang straight... bout like Rocky working out in that crappy old gym instead of a clean, organized, cutting edge equipped, air conditioned workout center! :rolleyes:
... and we'd all likely give left testicle to have your setup! Great looking work you're doing
It has been a long road to get here, and still working on finishing the shop.
And the challenge continues, taking the cancer out and shaping new steel.
Leaving the corner for the modeling
Just to give an idea of the process, first a rough piece with a bend.
Mark the edges
Cut the rough shape and start to grind and fit.
Corner picture
The rounding of the edge is done with the stretcher
Next fase is getting the propper curve in
Took the kick panel out.
To much rust between the panels to leave it in, now I can replace the corners of the top parts and repair the kick panel properly.
I must do this on both sides. How did you deal with the spot welds? Where did you start? It doesn't "appear" to be as difficult as I expected.
I started with drilling out the spot welds on the A pillar, from the rear (door) side. Then finding the other spotwelds and drill the out. After that I took a thin cutting wheel and cut the welds on the top side of the panel.
A little wiggeling and it came out.
You are truly skilled!
Its just a matter of looking how it is done, take it apart, replace the bad parts and put it back together.
I do believe it is a waist of time to fix things and leave rust hidden between the body parts. That is just creating work in the future.
