$3500 for a complete tub isn't that bad, actually I think it is pretty good.
hey mate sweet build up looks like its coming along pretty well, just wondering what brand of glass tub your going with and how they're priced, i know theres a place up the sunny coast called oz-east fibreglass but they want at least 3500 for a tub
also where'd you source the brackets for the rear discs????
cheers
dan
Did you use the welding method I prescribed or a different method?
Long-term cracking was also a concern for me. The fact that the pump bolts into the pump assembly was the big reason I wanted to relieve as much mechanical stress as I could.
- Eric
"You can only put a solid rotor on the rear if you want to register the FJ40 in Queensland, not sure about the other States in Australia."
Why do you say that ?
I have vented rear disc kits on the shelf for other cars, don't have them for a 40, but have never been asked. Why do you say they have to be solid to be approved in QLD ?
Hi,
It's something to with the age of the vehicle (my FJ40 is a 1974 model). Even though I have put a 1984 FJ40 FF rear axle which had drum brakes on it, no vehicle of that era had vented disc's on the rear.
Vented disc's were appoved for the front only and solid rotors were ADR approved on vehicles first, then solid rotors were approved for the rear, followed by vented on the rear of vehicles in the very late 1990's.
I was told that putting vented on the rear would not get approvel due to the weight of the vehicle and of its year. Also the fact that it was a live axle. FF and that I could not show that any other LC or Hilux with a simular axle setup had a vented disc whereas there is with solid rotors.
It's the same for the tyres & wheels, in 1974 there was no tyre sticker for the FJ40, so they revert back to only allowing a 30% increase from what was on the vehicle as standard and that was 16" rims and it relates to the overall size on the tyre as well.
So I installed on the rear of my FJ40 caliphers from the front of a 1984 Hilux which had solid rotors which later appeared on vehicles on the rear. The person doing the Blue Mod Plate roadworthy, as soon as I told him I was doing disc brake rear the first thing he asked was it a solid rotor.
Also I have been told that if you want to register a vehicle with a motor change as from March 2008 in Queensland you will only be allowed to put a simular motor into a vehicle as the one you took out. That is a 6 cylinder petrol with the same capacity as the 6 cylinder petrol as you put in, 4 for 4 and V8 for a V8.
Rob
mmmm ok I would suggest that whoever told you that is wrong. Under the codes your vehicle should now have being LG1 (Design) and LG2 (Modification) there is no requirement for solid rear rotors.
In the relevant ADR 31 is makes no mention of it, depending on the ADR's your Cruiser has to comply which is on its plate, it maybe pre ADR 31, there is no issue with upgrading to comply with ADR 31. being a 74 it should be ADR 31 compliant.
I would be interested in finding out which engineer told you about the vented brakes being non-compliant and also what AO and Design number your rear disc conversion complies to ?
Out of interest I confirmed this with QLD Tpt today whilst I was discussing an ICV I am building which needs to be 2007 ADR compliant and funnily enough has vented rear rotors.
Cheers,
