You have any more info on the upgraded front wipers?Oops, never mind. I should add however, that these look like a perfect match for the upgraded wipers that Lexus dealers are selling for the front and have worked famously through ice and snow.
Here ya go-You have any more info on the upgraded front wipers?
Thanks for the info! These appear to be the wiper blades themselves as opposed to the upgraded wiper arms. Any info on the wiper arms and if those could be upgraded?Here ya go-
85212-YZZ2F-LX (560mm), 85212-YZZ2G-LX (600mm) (double check those #’s)
It looks like they’re available for $15-$20 each. I’d say they’re worth it. Once the blades wear I’ll figure out what refills will fit it. The Lexus parts guy said there aren’t refills made for them, but I often find answers they give me to be less than accurate.
You are correct Mr. Wick, those are only the wipers, not arms. I don’t know if there’s an alternate wiper arm.Thanks for the info! These appear to be the wiper blades themselves as opposed to the upgraded wiper arms. Any info on the wiper arms and if those could be upgraded?
Thought the same thing- prius calls for a different different part number but fit and position looks similar. Might be worth ordering and trying.So I was sitting behind a Prius looking down on it for not ridding the world of discarded dinosaurs, and I noticed that the rear wiper looks like this. Can anyone confirm if this part was sourced from a Prius? There are some in my local junkyard, and I'll pull a wiper arm if so.
I took the wiper off of my wife’s 3rd gen Prius, and it did not fit correctly.So I was sitting behind a Prius looking down on it for not ridding the world of discarded dinosaurs, and I noticed that the rear wiper looks like this. Can anyone confirm if this part was sourced from a Prius? There are some in my local junkyard, and I'll pull a wiper arm if so.
So I took the plunge at Pick and Pull and it looks like the early Prius wiper fits perfectly. I mounted it on a Pick n Pull hatch and need to transfer to my truck, but I think it is gonna be just right.I took the wiper off of my wife’s 3rd gen Prius, and it did not fit correctly.
