Rear Heavy Duty Swaybar owners got links that last? (1 Viewer)
I wish everything was made like these Seriously. Is that asking to much?
Stock sway bar here... I need new links anyway... Might as well sign me up if there's still inventory. Bushings and swaybar disconnect too please. No rivnuts needed.
If I make it onto the list, a phone call/PM might make this easier.
Thanks again Phil!
Phil, on this one, is the upper mounting bracket reversed? If it is, does it matter?
Possibly :hmm: You will know its installed correctly if your link is vertical.
@Shoredreamer show off! Just kidding, that looks like a nice setup.
Thanks! I’m hoping this is the last time I have to mess with my suspension. I’ve cheaped out too many times, so just gettin it done right!
Nice Looking forward to feedback.
Install note - You want to use the supplied washers if using rubber bushing but not when poly bushings are used.
Noted. I have the poly bushings. And I will check to see if I need to flip the frame mount and if it’s vert.
Currently, the final raw parts are being Yellow zinc coated.
I will be reaching out to the Lay-A-Way guys soon.
We went to Yellow zinc because most guys painted the clear zinc. You can also paint the yellow zinc without issue if preferred.
Still putting these links to the test. This time 4 days of salt testing running beaches.
Wait, how can we see how they are standing up to all the salt with all the sand encrusting them? :hmm: There is about a bagillion gallons of water just to your right sir!
Looking forward to these, enjoy the outing, the vast majority of us are envious!
Can you make an option on your site for the rubber bushings and links WITHOUT the frame inserts? Last i checked didnt see that as an option.
Yes Ill post an option later today.
Thanks for pointing it out
Those are sexy. Im not going to paint them. Look very nice.
Looked like most painted the past clear zinc so we went with yellow zinc this time for fun. I do agree they look cooler sadly I will not be getting a set this round. You guys keep me so busy my 80 has all prototype parts and never gets the latest greatest.
