RFB
97 FZJ80 LIFTED SC DUAL BATTERIES,37s
I wish everything was made like these Seriously. Is that asking to much?
Thanks again Phil!View attachment 2159555
Phil, on this one, is the upper mounting bracket reversed? If it is, does it matter?
You will know its installed correctly if your link is vertical.Thanks! I’m hoping this is the last time I have to mess with my suspension. I’ve cheaped out too many times, so just gettin it done right!@Shoredreamer show off! Just kidding, that looks like a nice setup.
Noted. I have the poly bushings. And I will check to see if I need to flip the frame mount and if it’s vert.Nice Looking forward to feedback.
Install note - You want to use the supplied washers if using rubber bushing but not when poly bushings are used.
There is about a bagillion gallons of water just to your right sir!Currently, the final raw parts are being Yellow zinc coated.
I will be reaching out to the Lay-A-Way guys soon.
We went to Yellow zinc because most guys painted the clear zinc. You can also paint the yellow zinc without issue if preferred.
Still putting these links to the test. This time 4 days of salt testing running beaches.
Can you make an option on your site for the rubber bushings and links WITHOUT the frame inserts? Last i checked didnt see that as an option.
Yes Ill post an option later today.
Thanks for pointing it out
What about the front heavy duty sway bar axle mount. I sent a couple pms rearding it. Can u add it to the page. Thanks
Those are sexy. Im not going to paint them. Look very nice.
