Hojack
♠️Project Snowball❄️
My 80s rear with parking brake works just fine...
I did this type of rear disc conversion on my 40 a long time ago. It is a good upgrade, but the 40 has the parking brake on the transfer case already, so it was an easy, cheap solution. However, on the 60, I feel that the cost of doing this plus the transfer case brake (which isn't the best) isn't worth it. Get the stock system in good shape.I am not surprised this turned into a purist thread. Not a single person linked to a disc kit and instead pushed for swapping in a whole new axle which is ridiculous given the question.
I whole heartedly stand behind my rear disc conversion having owned Cruisers with both. The disc's stop way better especially on a loaded rig. The rear discs will completely lock up a truck and trailer with trailer brakes.
Check out TSM Mfg.
TSM Mfg now Rustic Disc Brakes
We proudly provide, Rear Disc Brake Conversions for most rear drive vehicles and drive shaft parking brake products, wherever possible, designed, machined and assembled in the U.S.A. We supply complete kits taking all the guesswork out of parts needed towww.tsmmfg.net
Downside, you need to figure out an ebrake when converting for at least the set I have. This can be achieved fairly easily with a Tcase brake. I have hydraulic line locks in place of a tcase brake kit which I don't reccomend but it works. I also have a wilwood adjustable proportioning valve to balance the brakes and a FZJ80 Master cylinder with upgraded 93/94 T 4Runner front calipers.
There is no reason to keep the known underpowered brakes on these trucks when cheaper options are available to increase the vehicle safety on a 30 year old truck.
Check out TSM Mfg.
Me thinks It's really not worth the effort or expense for the marginal gain it could bring.
For the 30 years I owned my 60, (frequently driving it overloaded) the thought of upgrading the rear brakes to discs never even crossed my mind. When the factory rear drums are working correctly, they stop the cruiser fine.
Technically the drum brakes have much more braking power than a disc. The disc is self cleaning and better cooling.
If you are running big tires, upping the engine, hauling a lot of load or heavy towing then an all around brake upgrade would be ideal. For a run around basic cruiser the stock setup works great.
Seems it’s easier and cheaper to start with a booster/mc upgrade. Then up the front setup and if still needed go after the rear upgrade.
I don’t think everyone is a cruiser purist but when you buy a 60 and spend a ton of money to make it a boxy 80![]()
Post some pics of your rig!I have a V8, 37s and a 7k pound 60 that tows a 3k pound trailer. Rear discs are a huge improvement and its a lot cheaper than paying someone to source and swap in an 80 FF axle![]()
First two are pics of the disc kit for ya. Its not the prettiest since my truck needs some underbody love.Post some pics of your rig!
Admit it though, having 4-wheel disc on a 60 is sexy !
What if I already have a matching FZJ?I’d get 80 axles to ditch my spacers....the sole reason I’d swap. I’d even want to keep it leaf sprung.
i think everyone needs to buy 80s and ditch the flares instead of swapping all these fancy parts on a 60, hehe.
why didn’t I think of that? What should I do with the 6.0 LS that’s in it?Then I guess you’ve got your donor vehicle. Save the frame, suspension & axles and crush the rest.
Your 60 weighs 7,000 lbs? And I thought my 80 was a fat pig.I have a V8, 37s and a 7k pound 60 that tows a 3k pound trailer. Rear discs are a huge improvement and its a lot cheaper than paying someone to source and swap in an 80 FF axle![]()
That is totally crazy! Just like me, it needs to go on a diet!Yes. Without getting too off topic I put it on the scales last year fully loaded and it came to 7.1k truck. 3.2K trailer. Combined 10.3k total.
