I recently regeared and rebuilt both axles. How much grease did you pack in bearings on last rebuild? Over packing might explain condition of diff fluid. In my research I decided not to add any more than what FSM instructed. As to leaving out the spindle end seals, consider this: Yes, most FF builds don't have these seals and rely on the diff oil to lube wheel bearings. Most are freight haulers or semi's of some sort that haul heavy loads. But these diffs are also not used in river crossings or experience extended off camber conditions that might starve upper side of lube. Most Toyota FF axles are designed for these other conditions that semi's do not normally see. There, I've said my piece.Bumping this thread. I’ve been having a bunch of weird issues like my driveline running smooth on the highway one way and then grumbling on the way back after being parked, both with regular driveshaft and DC.
Also my rear locker dash indicator started flickering on and off and is now on full time.
Been meaning to change the diff oil as it’s been some time since last change. Finally did it and full of grease with pretty thick stuff on the diff plug.
Inner seals were last changed at regear so 10 years and 120K miles or so. Everything is much quieter and smoother.
So I’m not going to reinstall inner seals based on this thread since I really don’t need another maintenance item.
Question is if there’s any need to go nuts getting the grease out? First thing is whether or not the diff lock sensor issue is related, meaning it’s in a position to have a grease coat on it that’s causing malfunction?
Second is outside of cleaning the grease out of the bearings/outer axle that’s accessible, anything else to do beyond running a cycle or two of cheap oil to flush it?
I didn’t know this whole issue was a thing, not looking to OCD it, just basics on effort to get to “just gear oil”.
