Ok, on to the tools list. I have 3 full sized rolling toolboxes to scavenge tools from and it is a 20 mile round trip from the farm house garage to the lake house where I am staying so I would like to keep from having to make runs back for tools and such. I am assuming I can do one side at a time so I will need the following:
Bottle jack, spacers if you are lifted (Floor jack if you can)
Jack stands (if you plan on having both wheels off at the same time)
Wheel lug wrench (22mm - same as 7/8")
Hammer
Sharp chisel (dust cap removal)
Wire (tying broken half shaft together)
Duct tape (tying broken half shaft together)
Large zip ties (makeshift dust cover for hubs)
Zip lock bag (makeshift dust cover for hubs)
(2X) 2 Liter bottles (makeshift dust cover for hubs)
Latex gloves (makeshift dust cover for hubs)
Box cutter (makeshift dust cover for hubs)
12 mm 6 point socket (hub flange nuts)
14 mm 6 point socket (front drive shaft)
14 mm box/open end wrench
Ratchet
Breaker bar (in case drive shaft has been torqued beyond factory specs)
Brass drift
White paint pen (marking orientation/position of front drive shaft. Make an index mark on each end of the drive shaft and the two mating flanges)
Mechanic's gloves
Rags
Questions:
Snap ring pliers (size?)
To do after emergency repair:
bored out hub flanges (make them and put them in with the recovery gear)
Related threads:
https://forum.ih8mud.com/100-series-cruisers/231347-front-drive-shaft-removal.html
https://forum.ih8mud.com/100-series-cruisers/362386-diy-replace-front-bearing.html
Attachment(s):
(see Attached Images)
I am going to document this procedure and do a proper write up for the FAQs seeing how this is probably going to happen to a few of us in the future. Any help with the tools/supplies list would be greatly appreciated!
