- Thread starter
- #41
Out in the garage with no internet and stuck on the part where you remove the hub flange. Went back to the lake house for my Mud lifeline. I'm not sure I understand exactly what direction to hit it from. Could not procure a brass drift so I have been trying to use a flattened section of copper tubing to keep damage to the wheel assembly at a minimum. Started with the copper and a hammer, then on to a BFH, and finally on to a Reese trailer hitch ball joint thingy. I am afraid I am doing something wrong because the hits to the hub flange make the earth tremble.
Dan, call coming your way if you don't mind.
...you'll need to leave them off and tape up around the bearings to try to keep as much grit out of the bearings as possible.
