I'm in the process of trying to install my new slee rear bumper. In the process I made the mistake of following the pictures on the instructions instead of the words (I installed a plastic skid in the position for the rear ladder instead of the location for the tire carrier--I only have a tire carrier. These are the skids that help the tire carrier and ladder to slide cleanly on to the bumper when they are closed. Literally the 1st step in the install).
There are two of these, and one went on without a hitch--and is also already in the right place. The other one was very difficult to get on. As in the bolts were very difficult to turn. I eventually got it on, but it didn't feel quite right. Now that I realize that I have to remove the one that was difficult to get on, I can't get the bolts off at all.
As you can see in the picture, I've already bent the allenwrench in the efforts to try to undo these bolts (they are the "locking" type, with the plastic inserts to keep them from rattling loose).
Does anyone have any advice on how to get these off? I'm weary of doing any more damage to my tools of the bolts that would make it even more difficult to extract these.
I'm confused, because this is all brand-new hardware, and the nuts/bolts were already pre-mated (i.e., the nut was already pre-threaded part way into the bolt so there is no chance that I took the wrong nut and jammed it into the bolt.)
The one on the right is in the correct position and you can see that he bolt is well seated. The one on the left I need to get out, and you can see that the bolts are already part way unseated, and they spin freely with the nut wrapped around the bolt on the other side--I held the nut with a wrench on the other side while keeping the bolt from spinning with the allen-wrench, but that just caused the allen wrench to bend.
