Media Readers Rides, for pics and specs on your Toy(s). (2 Viewers)
Photo/Video/Audio threads
I have been driving and mud bog racing Toyota trucks for 15 years. I have an '80 Truck with a old style 22r block with double chain stock bore,crank,and rods, 20r moded head with 1mm bigger than 22r stainless steel 22r valves, double springs, titanium retainers, Shcneider cam,Weisco 10.5 pistons, Weber 38mm dges carb, 1 5/8' primary/long tube header, 3' flowmaster,factory 4.37 gears with locker in the rear/welded front, newer('88) 3" wider rear housing, 5" springs, 3" body lift, 5 speed. Truck has factory tach in dash and factory add on air conditioning. I run 36" bucksot mudders or 35/10.50 boggers or 34/9.50 super swampers depending on the track conditions(shoot me a line I'll explain why)
I also have an '84 extra cab. It has a Crane -14 Cam, Weber 38mm dges carb, 1 1/2 primary long tube header,3" springs, rear locker. I did use this truck to pull the other one to the race tracks.
bought an F-250 diesel so I can pull 2 at a time now
Dang diesels.... You think you're soooo great!
Don't hate. Participate. :flipoff2:
Diesel Runner: that is a nice looking vehicle! Did you get your 2LT-E from Jarco? Any pics of the swap itself? How's the head, or have you put a 3L head on it?
Also: that is a wicked sweet Surf posted. I swear, someday I WILL find myself a fender with that mirror on it for mine (probably the same time I find a 4 door body).
Don't know how I missed these two, but those are some nice looking diesel rigs!
Dan
First poster here. Been lurking for a bit but decided to sign up and participate here and there.
Anyways its a 1987 SR5, 5spd. Purchased it in Nov of '07 off of 2nd owner with 103,000 miles on it. Ive put about another 4k since then.
No modifications. Simply riding on 31 inchers with an old Warn front as well as a rack on top from a company that no longer exists, i forget the name.
ive got plans for a lift around 3 inches, lockers and 4.88s within the next year.
heres som pictures of her in action...
Had no idea there were so many old toy lovers!
Well, I just sat and reviewed this entire posting. Some nice Toy's, some fresh beginnings, some projects well along.
My first time here. So Greetings! I owned an 87 Toy pickup while in the Air Force (Washington State). Spokane.
I am from Vermont (good 4 wheelin home of 'hellsville'=10 miles of powerline, rock, ledge, climbing, and bogging all in one).
At anyrate. Since that first truck *deep breath* I have missed her for years. About 2 years ago I found an 88 and bought her for 800.00.
The memories of my military days and the offroading etc...*ponders off*... oh, yah where was I...
I have been nursing her slowly to better than new each time I do somthing to her. Shes basically stock for with some embellishments.
My long term plans are for serious suspension, lift sufficient for good articulation, LS differentials, at least 33x12s, off roader shocks yadda.
What I have done: Replaced the front quarter panels. But first rhino lined them inside and out including new paint. Then rhino just above the infamous Toyota body seam down including the entire bed. (Stop the bleeding right).
Just prior to that I had the frame worked on ... spent allot of money to make it stronger than new.
Next new shocks and gloves. (Not the ones I want but good for now).
Ripped out the interior carpet went with one piece black vinyl/rubber with pad for noise reduction.
Had one valve which eventually went. I found a used engine and put that in. had all the seals replaced.
No better time to replace the clutch so put in a centerforce comp. unit.
She was top of the line for her day. AC, power windows, casset tape radio (I am serious!).
She's getting some minor front end work this week or next but nothing major.
If work picks up and the money tree seeds grow I just bought I hope to grow enough cash to make the bigger changes. ;)
1989 hilux excab
This is my truck named "master yota"
I purchased it from a friend in jan 07
w/216xxxx on 22re now about 230xxxx
bone stock w/ new paint. This is my D.D.
33/11.50/15 kumho road venture mts
which they discontinued
great tires I might add
rear trd elocker 4:56
ifs front 4:56
cranked t-bars
2" rear fabtech blocks
2" body lift
custom winch plate
warn 9.5xp
warn 4x lights
KC slim lites
kc rock lites under bed
trail gear sliders
4x innovations t-case mount
bud built x-member
New Guy! My Ride!I
I have a "New" 1985 Toyota PU SB 4WD. I have completely overhauled this truck. It has a remanufactured engine(22R), Offenhauser Dual Plane Intake, Weber 32/36DGV Carb, LC Engineering Stainless Header(Jet Coated), HD 3 Core Radiator, Full Magnaflow Exhaust 2 1/2", Speced Distributor, K&N Filter. The body has been completely stripped and repainted in 1992 Toyota Supra Red, custom made shell, carpet kit, American Racing Baja Rims, 31 x 11,50 Geolanders, Gorilla Locks, Skyjacker Shocks, and all mechanicals replaced or rebuilt. Looking forward to Toyofest 2008 and just have cleaned bottom side and undercoated and painted and cleaned all suspension components. Cool site here. Lots of good info and pics.
1985 pickup
-33" cooper STT
-brand X spool (dont remember)
-revolver shackles
-rancho excessive travel rear shocks
-front "lift" shocks
-header
-MSD 6al
-86 rear end
thanks Im in the proces of swapping a 92 P/U cab and box I picked up for $50.
it needs a little rust fixed which wont be a problem with my being a auto body tech. and after its fixed its getting sprayed black with kawaski green flames
Been building up my new Toy for the past couple of months, it's coming along. Next up are Bud Built skids, some 4xInnovations sliders, and a tire carrier for the tube bumper. I still have my FJ80, but it's been retired to mostly street duty and for the wife to haul the kids around.
Mods so far:
ARB Bumper
AllPro Rear Tube Bumper
Toytec/AllPro Lift Components (around 3" of lift)
33" BFG ATs
Bob'd Bed (From a Longbed Length to a Factory Shortbed Length)
A.R.E. Truck Cap
Some Herculiner after the Bed Bob
Hella 500s
CB/GPS/Navigation
Corolla Bucket Seat Swap
AR 767 Steel Wheels
Maintenance Done So Far: It's the 22RE with a 5Speed
New Timing Chain and Guides
New Water Pump
New Oil Pump
New 3.0 V6 Radiator, Fan Clutch
Dual Stage T-Stat
New Plugs, Wires, Dist. Cap/Rotor
Amsoil Fluids
Marlin Crawler Shifter Bushings
Some Pics as it sits now:
Here's how it started back on Jan. 5th when I picked it up from the previous owner:
small blocked 94 ext cab/89 4runner
Like the subjects says, post a picture of your truck or 4Runner, and tell us about it. If you have a lot of pics and mods, and feel up to it, sign up for the rig of the biweek, and you'll get a whole thread to yourself! :D
Lets keep the chat to a minimum (That means none! :D) If you have a question about someones truck, start a new thread, or PM them, so we don't clutter this up.
My name is Manny and I'm from Austin.I have a 94 ext cab with a 355 smallblock chevy,9 inch rear,s.a.s.,37 mtrs,to name a few.My 4runner is an 89 with an s.a.s.,40 inch boggers,pretty much stock except for gears.
My name is Manny and I'm from Austin.I have a 94 ext cab with a 355 smallblock chevy,9 inch rear,s.a.s.,37 mtrs,to name a few.My 4runner is an 89 with an s.a.s.,40 inch boggers,pretty much stock except for gears.[/quote]Heres the 9 inch built by Bill Buck racecars in Austin.
Here my rig with specs and pics.
85 front axle
Hi pinion w/529's and arb
30 spline long's
TG six stud knuckles
Ram assist coming soon
5" TG front springs w/5" shackles
V6 calipers
14" travel Bilstien shocks:frown: W/TG hoop
and 2" wheel spacers
For the middle.
22RE stock
Downey header w/Magna Flow hi flow cat and Magna Flow muffler
W56 tranny
TG dual case adapter
TG 4.7 in the rear case w/triple drill flanges
TG cross member this the only pic
The rear specs.
V6 3rd member w/529's and arb And TG stud eliminater kit.
TG 56" 5" rear springs and 5.5" shackles
Pro Comp MX-6 shocks w/12" of travel
W/1.5" wheel spacers
sitting 36-14.50-15 TSL radials
589 American Eagle rims
Some action shots
And my tow rig
2000 Super Duty w/7.3 power stroke
3" lift on 315 BFG all terrains
4" exh and K/N filter charger
my toy, yama tech
It would have looked good in the back of my new truck.
-2005 yamaha yz250f, Hinson clutch basket, black excel rims, motion pro clutch/throttle cables, Sunline billet throttle, keithcarb (stock) jetted, tag T2's 1' risers, renthal sprockets did oringchain, titanium 5valve all valves redone, twin air filter, Etnies/Dc graphics (custom) (not in picture)w/black plastics (fenders F/B), michelin starcross tires+ paddle tire dune grappler tire, renthal grips, ASV unbreakables, orange Sunline shifter, and a few other things
here are a few pics of my rig 1994 toyota 4x4 22re
mods:
downey fiberglass fenders
downey dual shock kit w/ billys
downey idler arm brace
budbuilt skid
budbuilt x member
OME torsions
SDORI BJ spacers
new ball joints, idler arm
engbldr street RV head w/ 261c
engbldr Timing chain kitw/ steel rail
LC oil pump/water pump
LC valve cover
Downey intake
LCE header
Flowmaster
LCE wires, cap,rotor
Low pro stops
clear corners
Grant steering wheel
RJS 3 point harness
3" shackles (not installed yet)
rear billys
total choas brace
33x10.50x15 BFG muds on street locks
(the street locks where free so dont hate on them...lol)
Home Headlight up grade
yukon's 4:88 with a loc rite in rear
hella cool hella 500's
custom 1 piece driveshaft
custom exhaust out the side
marlin rear bumper
dave'z off road tube doors
SDORI tow point
Hi yall ,
another toyota buff , i own a few but here is my trail rig specs .
this more of a mud type truck for our southern Alaska trails with lots of mud and water crossings .
specs .
motor was a 22r with 230xxx miles till a rod let loose in a mud bog
85 pickup 5spd w-56
351 windsorv-8 efi out of a 91 bronco being installed now as i post this ....
all pro t-case e brake
welded rear
limited slip front with stock 4:10's
NWOR adapter /clutch
home brew bed out of polaris crates ,and air force aluminum pallets for the bed sides and sch 40 pipe
35's on chevy magnesium rallys
