Raptor good or bad for value? (1 Viewer)
BOISE, ID
I find myself shying away from anything with liner on it so funny I'm considering it. Thinking just the bottom and wheel wells. Mostly the durability in the wheel wells is what is appealing. I've heard both sides of it...good bad, purist, blasphemy, etc. Obviously if everything is documented with before pics it helps down the road if you ever had to sell.
SNLC
OCD
Supporting Vendor
Boise - Idaho
Generally speaking, bad.
Lots of stuff about this in the 80-series section. It was real popular on 80’s 5-10yrs ago. Now people are stripping it and it one big job.
Cheers
GRM
Finding new adventures in old jalopies.
Moderator
Livermore, CA
Raptor is more like thick paint than bedliner. I dont worry about it on junk paint because its easily sandblasted off.
GRM
Moderator
Livermore, CA
Which ones from rock auto off a 92? It seems like there are multiples and I apparently have already bought the wrong ones haha.
There are some that are 10in x 1-31/32 IN. Would those fit?
Same thing with Linex?
the linex on my ram is a rubber coating. Easily 10x as thick as raptorliner.
40Man
Spokane
Agreed, I put Raptor underneath after seam sealing and painting because it adds protection and comes off pretty easy. Linex is much harder. Haven't tried to remove it, but had it on my Tundra bumper. I abused it and it held up crazy well.
BOISE, ID
So raptor is like a thicker textured paint? And it will for sure blast off? I was thinking it was like regular liner just tintable
Hey GRM, you have blasted it off before? If that's the case I would feel better about using it
GRM
Moderator
Livermore, CA
Its like a thick textured durable paint.
I have not blasted it off, but we use it on equipment at work and the guys will hit it with a wire wheel to weld, then touch up the spot.
Rainman
Wondering what my next vehicle will be...
Franklin, Tennessee
This is interesting. I haven't heard of anyone saying Raptor was bad for value. I used it on a build inside and under the tub to A) seal all the clean new seams with a protective barrier and B) to protect the rear floor frame scratches and surface rust. (helps keep things from sliding around in the back.)
Besides that, it's easy on the eyes and knees.
Arkansas USA
In my view Bad for value if put on over problem areas on an urestored rig. It would not be a negative to me on an obviously fully restored rig.
djcfj40
Uniontown. Pa
I agree with Rainman
It’s good to provide some extra durability and protection but it’s definitely not like rhino liner or linex. I used it on mine just like Rainey did on his. It’s easy to apply and touch up yourself and if you need to remove it somewhere down the line it’s not going to be a life changing experience.
40Man
Spokane
I had half doors with it. I sanded them down with a DA sander in no time. Came off quite easily.
I would say it really is debatable if it affects value. Also unless all the spot welded seams are sealed, moisture will get underneath it. A stock 40 body has a lot of seams so that's a difficult process. But worth it in my opinion whether your applying bedliner or not.
New York
