Quit burping coolant, today. Project Wrong Way.
BenjaminCA
Oroville CA
Website
www.youtube.com
Grab your Pepto-Bismal, your burping days are over. Got some advice from a friend to ditch the burping and get with the OEM tools coolant pressure refilling system. Also works as a scuba system.
OEM Tools Coolant System Refiller Kit, I Test It, No More Burping Coolant On Landcruisers.
Waiting for the scuba video.
The heater hose on the back of the head is the high point of the system, any air bubbles you need to worry about will go there. I have a flush kit "T" fitting on mine, I just take the cap off, as soon as water comes out, it's full, no air pockets... Just removing the hose from the head and putting it back should accomplish the same thing with very little air (only the amount in about 6" of heater hose) will remain.
To test the system, get a pump:
Amazon product ASIN B0002SRGWUor similar, this kit included the correct cap for my FJ40's stock radiator.
By creating pressure inside, instead of a vacuum, you will see the leak, it will squirt out, or cover joints, suspect points with soapy water and look for bubbles like finding leaks in a tire.
