Question on 15w40 engine oil…diesel oil ok?
sleepycruiser
I will get by….I will survive -Touch of Grey LC200
Asheville, North Carolina
My last oil change I used 10w40. I changed it about 6 months ago and put minimal miles on it, but thinking about putting some thicker oil since it is getting colder and maybe I will see less drops underneath (very minimal dripping now).
I’m also reading contradicting amounts for a 1964 F (135) engine. I’ve read 7.5 quarts and I’ve read 9. I can’t recall what I put in last time. I’ll have to reuse the drain bolt gasket if I want to get it done today.
Is this ok to use? Looks like it should work in diesel and gasoline engines.
Your logic is contrary to the normal manufacturer's recommendations: higher viscosity in summer and lower viscosity in winter. Given today's modern multi-viscosity blends, I'm not sure that's sound advice anymore. I would think you wouldn't want to go higher than 10W40 but you will get all kinds of different opinions on this subject.
If you're looking for good and relatively cheap, I would think this Shell Rotella diesel 10W30 would be a good choice:
Worst day of my life…getting corrected by an Auburn fan! Haha!!
But yes, you are correct. Too early this morning. I don’t drive it very often in the winter, so mainly want to stop the few drips with thicker oil.
No problem running diesel oil such as Shell Rotella in a F engine. I have a rebuilt 2F that has > 300k miles on it that I have mainly used Rotella 15-40 in it. For your area the 10-30 would be a better choice.
Thanks. I might just keep the 10-30 then.
Edit: actually I used 10-40 last time.
"Being Rebellious"
FWIW - I have an '86 2F rebuilt, and installed in my rig about 10 years ago, I've run nothing but 20W50 since.....that was on the recommendation of the engine builder. Also, I daily drive my 40 year around. :hillbilly:
"Being Rebellious"
Heretic.
I had a 22R, bought it with ca. 25k on it, when I sold it it had > 200k and I ran Castrol 20-50 during that time.
It seems to me that your concern is oil leaks: leaking gaskets, seals, o-rings may be able to be fixed with an oil additive for leaks, but it is temporary at best. Thicker oil will not fix a leak. Leaks need to be fixed with new sealants, seals, gaskets, and whatever. Disassembly required. New parts required. Find the leak. It may be simple. A rear main is a major PIA.
"Being Rebellious"
This. 20W50 all day long where I am located.
This has a zinc additive so you are good there with the flat tappet cam.
I use 15w40 dello for the zinc.
Diesel motor oils must withstand a lot more pressure than gas engine oils.
Dello is available cheap locally and I keep it around to run in our Diesel engines too.
How do you tell you're handling a "Diesel" motor oil?
The API certification will be either c followed by a letter or s followed by a letter.
C for compression ignition
S for spark ignition.
The letter after that denotes the grade. Closer to z is a better quality oil according to the American petroleum institute.
