- Thread starter
- #141
Yes that is a GT500 under the cover.
No, I don't drive the Super Duty every day. It's here to tow s***, soak up insurance premiums and otherwise occupy space. I don't get the concept of daily driving something like that. For what the tires are going to cost to replace I could buy a used commuter and drive it off a cliff every three years and still come out ahead.
It rides a ton better, the ride is far less jarring than before. It rides very well. Very compliantly. I should say that this is not an indictment of leafs, as my rock crawler rides awesome and is on leafs all around. Your ride quality has much more to do with spring rate than with link type. Longer leafs mean more travel, less axle wrap, less spring rate for the same ride height.
Before everyone jumps on the 3 link bandwagon, spring-over, shackle reversal with 50+" front springs would net you an awesome quality of ride. Did I mention you're probably going to save thousands of dollars doing this?
Here's a link:
That said, I do not have enough shock valving on the rear of the FJ60 so it has a bit of oscillation on the bumps in the back. It's not bad on the street, but my first experience running the dunes at Pismo meant the rear had a tendency to bounce at speed. It would handle better with much more dampning as a rising rear is an unusual driving experience.
I think I'm going to upgrade to Bilstein 7100s with a base 360/80 NM valve stack and see where I can go from there. The front seems to be close for now, though I'm thinking I'll probably be served tuning those as well. Though I can't really tackle the front until the back end of this is more manageable - I'm just not feeling the urge to spend $500 right now on another set of shocks.
@FordFascist can you quantify/explain how much better your new suspension rides or performs? Maybe hard to say objectively because of your hard workbut I'm def interested to hear what you feel like you gain on & off road
Here's a link:
