Why have a switch in the cab at all?
I like what rice found.
It won't harm anything running in the colder months. I'd skip the switch. It's not necessary and adds unneeded complexity.
Looking really good Jon. I would not use the aluminum AN fittings on the pressure side of the power steering. Contact PSC Motorsports Online for the proper steel AN fittings and pressure hose. Also make sure that the AN adapters you are using on the steering pump and the steering box have the proper flares on them as well.
It is generally accepted that the aluminum will not handle the pressure. I use the steel adapters as well to be on the safe side. I don't believe that proper pressure hose will fit in the aluminum fittings either. Won't swear on it.
Stan is correct on the aluminum fittings. Definitely use steel for the pressure side. I've never had a failure with aluminum fittings, but I've always used steel fittings.
Ordered steel AN adapter fittings...but I'm still a bit hesitant to believe the aluminum ones can't hold the pressure. As an experiment, I'm going to run the aluminum until they create issue, but have the steel ones in the truck. At the rate I put mileage on this thing it will be decades before they leak.
