Saginaw pumps are 800-1200psi depending on the specific flavor.
I totally missed this was a power steering application .... my bad. Thanks.
If those black fittings you show are steel-cool. They look like aluminum. Make sure you use high pressure hose as well.
Ordered steel AN adapter fittings...but I'm still a bit hesitant to believe the aluminum ones can't hold the pressure. As an experiment, I'm going to run the aluminum until they create issue, but have the steel ones in the truck. At the rate I put mileage on this thing it will be decades before they leak.
Did you get an original dash box, or the one from BTB/MAF?
Leave enough room under the axle brake lines to be able to slip an axle strap underneath? Gotta be able to strap it to the trailer without kinking the lines.
isn't that a job that normally gets outsourced???
