I agree. What I was hoping is if I could get most of the blue off down to the original paint I could touch up the areas that were metal bondo etc. don’t have but hope leftI don’t see how you don’t have to repaint that blue. Just not seeing it
It could be terribly expensive but you could try urethane bumper stripper on it. If the blue paint and primers are wimpy enough it may strip all but the green. It comes in spray cans, is expensive ($20 ish a can) and doesn't go real far but might be worth one can. As soon as the topcoat lifts wipe it off to protect the green. That green paint can take it because it is hard as a rock by nownot what I hoped for but still better than the horrible blue
This is a before and after for 60 series steel chrome wheels. This set it pretty rough looking but CLR like @wngrog uses on lots of his stuff plus fine steel wool makes pretty quick work of cleaning them up.
After I am using Meguiars carnuba wax to seal them up in hopes of slowing corrosion. I think they will have to see the wax quite often but it is easy to put on. This method will work on any chrome parts but don't do it on stainless trim. That gets polished.
Go with fine steel wool. I say this really because I don't know if coarse will scratch the chrome or not. Fine works great so ignorance is bliss in this case. Once chrome fails and gets pits in it, that's forever. The reality is that the pits are usually tiny and the rust bloom is huge. Once you clr and steel wool the crap away, it looks 100 times better. The wax is your friend keeping oxygen off of those bare metal exposed pitsThat is EXACTLY what my wheels need! Is there any particular type/coarseness of steel wool to buy? Man, that looks incredible!!!
Forgive my ignorance, but what is it about stainless that makes wax a no-no? Is anything needed on the stainless once it's polished?This is a before and after for 60 series steel chrome wheels. This set it pretty rough looking but CLR like @wngrog uses on lots of his stuff plus fine steel wool makes pretty quick work of cleaning them up.
View attachment 2255178View attachment 2255179View attachment 2255180
Finally had a legitimate excuse to go out to
Lowe’s and got some supplies. These just got added on to the list.
Wax is ok on stainless. I don't know that it will do a lot of good but it may offer a little scratch resistance. Like wax on a paint job helps keep brush pinstriping way down on the truck.Forgive my ignorance, but what is it about stainless that makes wax a no-no? Is anything needed on the stainless once it's polished?
I’ve only done that one side in the front so far. A couple pages back @7schulz mentions his process. Really no way wrong to do any of this. I suggest going through the whole thread though. Lots of good info that @wngrog puts out in here as well as others.What was your process?
Wow looks great? Did you do pretty much the whole exterior? I didn’t expect it to be so shiny when it dried on mine, I didn’t polish it though.Nearly finished, full 3 coats of Penetrol on the exterior and interior, preceded by CLR and (00) steel wool. Penetrol was applied in thin layers with 24hr between coats. I did this on all surfaces you touch or could rub up against. I then coated the entire undercarriage (frame, tub, engine bay, floor pan, wheel wells, axles) with Fluid Film. This would have been nearly impossible wiping on Penetrol.
