Power Steering Cooler - Replacement
Knoxville Tennessee
I just spent a couple evenings working on my 1994 Land Cruiser. The power steering cooler had some pretty bad corrosion/rust that lead to a leak in the "paper clip" cooler. To help the next guy I wanted to let you know what all needs to done to replace the cooler with an OEM part or like me, a used cooler. It's truly a pain but with some instruction you could be done in few hours. Before I start, I think in hindsight an aftermarket cooler would have been a lot easier to install and nicer to my wallet.
I bought a used cooler of Cruiserparts.net. Note: if you order anything from them, call and confirm the order and pressure them to get the part shipped out to you.
To remove the old and install the new cooler, this is what I did (or slowly figured out)
1.) Remove battery and battery box
2.) Remove fan and fan cover
3.) Begin draining radiator and pull the hoses off the cooler tubes (remove clamps)
4.) Remove front plastic grill
5.) Unscrew and pull out front turn signals
6.) Unbolt headlights and side markers
7.) (Only if you do not have a long 12 or 13 mm socket for nuts on radiator mount bolts) Unbolt radiator core from bracket on either side, 4 small bolts with square nuts on top of radiator. This way you can slip a standard C-wrench over the nuts from above.
8.) Unbolt radiator bracket. (2 straight down, 2 that go forwards with nuts (12 or 13 mm long socket should grip nuts
9.) Unhook large radiator hoses, overflow tube, and replace peacock to stop draining.
10.) Elevate Radiator or remove the other hoses to completely remove it.
11.) The PS cooler is held in by three bolts. Two on top of the cross brace of frame directly under the radiator. and one on the driver side longitudinal frame rail. All three of these need to be undone. I also unhooked the side mounting bracket off the cooler tubes (90 degree bracket) to get the tubes in/out of the small gap between frame cross member and frame cross member. I am not sure if this is necessary. I would try it without removing any brackets from the tubes.
12.) With the radiator elevated high or removed, you should be able to weave the old cooler out of and then the new cooler back into place.
13.) Keep track of which hose connected to which metal tube in step 3.
14.) Mount the new cooler in the reverse process of removal. Once the cooler is mounted, the car reassembly is the reverse of the steps above.
15.) Once reassembled, jack front wheels off the ground and have a buddy turn the front wheels back and forth while you add ATF fluid to the power steering reservoir until you think you have removed all air from the system.
16.) Add coolant or distilled water to the radiator until full.
17.) Start vehicle and let run for a few seconds, turn off and check power steering fluid res. level. Add if necessary.
18.) Cycle wheels back and forth a couple more times with engine off, checking PS res. level
19.) Turn car on and continue cycling steering lock to lock keeping an eye on the PS level.
20.) If all seems to check out, unjack the car and take it for a spin. Keep an eye on the engine temperature and also listen for power steering noise.
21.) After a quick drive, check for leaks, and check PS fluid level. Take action if needed.
I used a huge gm suburban cooler.
Nice write up.
I found this post very helpful replacing my power steering cooler on a ‘97 with OEM one, so thought I would comment just to say thanks and provide some additional thoughts/observations. An aftermarket cooler would definitely be easier to install and probably more effective at dissipating extreme heat/duty from what I have read but I am going for an OEM restoration so that was not on my radar. Nevertheless your thread was helpful and convinced me it could be done.
Couple pointers for those attempting this:
1. Having a 12mm racheting closed-end wrench made fairly easy work of the top bolts holding in the cooler (hit with some PB first if crusty - dont want to break a bolt there)
2. Radiator defintely needs to be moved up a bit but not completely removed nor drained, at least in my case (‘97 with CSF aftermarket radiator). There was just enough hose play on the driver side to slip two hockey pucks (or equivalent wedge) under the bottom radiator bracket which seemed to keep it propped it up just enough without popping any hoses. Draining the radiator and pulling hoses would be the easier path for maximum movement but I was trying to avoid that — although was my backup plan.
3. Removing the brackets that come on the PS cooler was essential for removal of the old one and replacement of the new one. It allows you to squeeze the unit together in a way that clears the weird angles and also reduces the bulk and immobility of the bracket itself.
4. Regarding the bracket, there are only two small (10mm) bolts holding it together and the only challenge there is remembering the orientation when putting back together (the bolt heads face away from the engine bay). Therefore when you’ve reached nirvana and replaced with the new cooler, put the bracket back together from underneath the rig so you have room for a ratchet to tighten them down before getting the top bolts back in place.
5. Blue painter tape is handy to protect the brand new unit as you squeeze and twist it back into the vehicle. I ran a strip along the lower body seam that runs along bottom side of the radiator area (top of the space you are squeezing through) and probably wouldn’t hurt to also run a strip or two covering the topside of the frame cross member (bottom of space squeezing through). I also taped most of the tubing on the unit just to avoid marring it up too bad. That seemed to work and left me with no scratches in the end. It also put your mind at ease when you get to almost need to force things as you finagle it back in. Part of that involves squeezing the tubes together to clear the angles and turns, which is why taking off the bracket is important.
With patience and determination, it CAN be done!
I run a Derale 2 row tranny cooler, and my tranny temp never gets over 190 in the most extreme demand when pulling steep grade or 4-Lo type hill climb. On freeway, it is barely breaking 160F with AC on full blast.
Thanks but this thread is about the power steering “paperclip” cooler.
get rid of the paper clip cooler....they will eventually break.
I misread...Here is a pic of my derale Power steering cooler upgrade.
You could say that for just about anything. Mine was fine after 30 years — I just replaced it along with a bunch of other stuff to refresh it. Works fine for most people unless you are using oversized tires and overworking the steering. For that, there are better coolers.
Can't wait to add it to my truck. It's 101+ degrees here in TX and that heat from the 3FE is absolutely unreal.
If you have a 3FE, make sure the kit is the right kit for you. The 3FE has the PS lines coming in from both sides IIRC.
Does the Cruiser and Company kit (and others like it) replace both the "paperclip" cooler and the high pressure "feed hose" Or just the paperclip?
I have always wondered that.
Wonder if I can have a shop build a hydraulic line to make this work on my 91? If that is a high pressure line, why would Cruisers and Company use simple hose clamps on it? Maybe the pressure isn't that much?
I can't remember now, but IIRC, i replaced all my lines including the low and high pressure ones and fittings for the Pump and steering box. Been working wonderfully for the past 6-8 yrs...
