- Thread starter
- #21
I've decided it's the input shaft that's leaking and the low pressure hose on the pump side.
Glad it worked out for you. Always better to start with the easy/ less expansive stuff first.I was sure my steering shaft was leaking. But, the low pressure hoses were old so I changed them first and no more leak.
View attachment 2374421there's an o-ring under that teflon seal. is that the one you couldn't find?
Make sure you get the pre-load correct on that spanner nut. If left too loose it will create end play and slop in the steering that is not related to the sector shaft and you'll be back in there.....
There's a teflon ring over an o-ring and under a steel washer on the pitman exit end of the gear.
The FSM calls out a special tool to iron that ring into position.
I polished the sector shaft where indicated and used it as the iron by inserting it backward into the gear box.
I wire wheeled all the loose crud off and then worked up to 400 grit emery paper to make that area smooth and useful as the assembly iron.
Should you follow that path, don't get into the seal area of the sector shaft with the polishing.
Did you count the balls, there are 44 of them. (just in case you find your-self crawling around on the shop floor with magnet).
1st: advice. Don't pause for 10 days during the rebuild. Memory gets foggy.
If I am not mistaken, a new OEM 44110-60212 Steering Box will have the 105 sector shaft in it, you’ll just need the 105 pitman arm.I believe all LHD 80 Series steering boxes are compatible across all years.
FJ80 steering box was originally part number 44110-60210.
FZJ80 steering box was originally part number 44110-60211.
Both of those part numbers have been superseded to 44110-60212.
If you have 1 box that is in good shape, the sector shaft is pretty easy to replace. I recently swapped my sector shaft and pitman arm for the 105 Series parts.
105 box by Adam Tolman, on FlickrCompatible, but see below regarding the pitman arm.I believe all LHD 80 Series steering boxes are compatible across all years.
Looks like that's right, here's a diagram of the steering boxes available for a 105, and here's a diagram of the individual parts, the 44110-60212 (105 series 2005+) includes the upgraded 44111-60060 sector shaft and calls for the 45411-60360 pitman arm . If you want the complete unit, then along with the box and pitman arm you need the nut and washer for the pitman arm, but the part number for those is the same across all the boxes so your original one will swap over.If I am not mistaken, a new OEM 44110-60212 Steering Box will have the 105 sector shaft in it, you’ll just need the 105 pitman arm.
Got a pic? Might jog my memory.I rebuilt mine, but is there a trick to getting the low pressure flare nut to seat so that I can thread it? I spent 45 minutes twisting that thing and can't get it to thread!
I'll get one tomorrow in better light.Got a pic? Might jog my memory.
Nope. It's just a b*tch. I did the same and eventually the leading threads caught and I was able to thread it in. Both high and low pressure nuts gave me fits.I rebuilt mine, but is there a trick to getting the low pressure flare nut to seat so that I can thread it? I spent 45 minutes twisting that thing and can't get it to thread!
They can be tricky. It's all about getting them aligned. I found it helped to use a screwdriver as a lever to keep light downward pressure on the line.I rebuilt mine, but is there a trick to getting the low pressure flare nut to seat so that I can thread it? I spent 45 minutes twisting that thing and can't get it to thread!
