teleskier
I was investigating how to restore my frame and body and it led me down a path of chemistry and discovery.
I initially was sold on powder coating my frame. A friend of mine owns Austin Speed Shop and they use a great powder coating company here in Austin. As I started to clean the frame I wondered how in the world the crevices and channels will ever get sandblasted and subsequently coated. Its impossible. It looks great, but I just was not totally satisfied.
I then considered galvanizing, but didn't want the look of a galvanized frame. I read some information on painted galvanized surfaces sent to me by Gary at Process | AZZ Basically, you can get paint to stick immediately (<24-48h) or after 1 year, but that requires sanding the surface. This is due to the fact that the zinc in the metal oxidizes and prevents paint bonding. Further, all the holes would need to be tapped and this would lead to exposed bare steel in the most rust-prone areas.
The hot dip process by which the metal is placed in sequential baths of alkali, water, acid, and then zinc is what was the most appealing about galvanization. If the frame was under the fluid, it would go everywhere and coat even impossible to reach areas.
Could I hot dip and then powder coat? Probably not, because the bare steel would flash rust leading to the need to sandblast again anyway.
Then I was on Hot Rod forums and the acid dipping process popped up again. A bunch of bad reviews because the acid would permeate the seams and then leach out somehow later. This was particularly true of seam sealer. If this happened after painting, it would wreck the paint job by bubbling and eating away at the paint. All of these forums concluded at the acid needed to be neutralized or washed to prevent this.
Then I found this place in Detroit called Redi-Coat. These guys take a car, bake off the crud (oven on clean cycle), dip it in alkali, then deionized water to clean, then acid to strip paint and anything else, then a rise, then zinc, then rinse, then a electronically applied primer, rinse , rinse, and bake it on. The parts come out like factory primed body panels. Following this, it would require seam sealing and then topcoat.
This process coats the parts with zinc for corrosion protection and then immediately primes it in a bath of electronically applied primer - same general principal for powder coating. The paths and neutralizing seem to address any leeching of acid others complained about with simple "pickle" baths.
Michigan Redi-Coat Site
Anyone ever do this or does anyone have any thoughts. I think I will do this and report back how it all goes.
