Poverty Pack Modifications / Feature Delete Thread (1 Viewer)
When no-AHC poverty isn't enough...you can get a blanking panel. (Insert your own empty pockets joke here.) This came out of a wrecked '98. (Pocket that's more common on an LC shown next to it for reference.)
Swapped my pocket over to the blank 58839-60020 when I installed the ScanGauge II mount from @CruiserGarage
Installed (2) of 55539-60020-C0. These are switch blanks to remove the (2) seat heater switches. High heat stopped working on the driver’s seat and when I got a look at condition of the elements, I chose to delete the seat heat.
Installed (1) 84656-60020 Switch Bezel (Replaces the antenna switch) during a recent swap from the motorized antenna to a fixed mast antenna from the Tundra. It’s not an exact fit for the antenna switch, but once it’s glued in place it’s not noticeable. This was not available domestically, had to get from partsouq
Nice! Likely your glued cover will hold fine. If it doesn't, 84656-60030 is exact fit antenna switch cover.
I tried to order 84656-60030 on a couple of different orders from partsouq, but couldn't get one shipped out. That said, partsouq has been a great resource for parts. It's hard to believe the shipping is so quick from the UAE.
Exactly! Actually, I'm the OP and I have NONE of these mods nor deletes. I just want to enable others. :)
But come 2023, I will definitely consider buying a white, poverty pack 105 series.
If Toyota were to celebrate the last year of the 200, by selling a Poverty Pack version for 35% off the fully loaded 200 (like it is priced in Australia), I'd be the first in line!
I second that
This arrived from Amayama. I have not done a test fit yet but broadly the dimensions seem like they would be accurate. As mentioned above, only the grey color is available at this point. Amayama seems to have more of these, too, and in case you need an ashtray and cup holder, the 60030 part (at admittedly twice the cost) is a slightly less impoverished poverty option.
What year tundra antenna did you use? Plug and play?
No need to use Tundra antenna - OEM 100 series *manual* antenna is like $35...Which is 100% plug and play.
(1) 86300-0C010 Tundra Antenna Assy
(1) 86309-0C020 Tundra Antenna Mast
(1) Metra 44-E18 Antenna Extension Cable
It's mostly plug and play. You do have to make a bracket to connect the antenna to the tab where the motor was mounted. I re-purposed this bracket from an old John Deere mower deck. Had to add a couple of old cushion retainers to get the antenna straight.
You’ll also want to disconnect/remove the power antenna relay behind the glove box door.
It's a winner. Slightly blocked by my ARB drawers but you can still get the cover in and out as long as what's in the pocket won't immediately fall out.
Are cloth seat covers available? I hate leather...
Same, I’m thinking about reupholstering mine in cloth.
My leather is cracking bad so it was either completely reupholster or find some covers, and @Bendcruiser showed me his from Escape Gear - wow they are TIGHT to his seat, easily the best I've ever seen. Hand made in South Africa, so not cheap, but they definitely give the truck a more rugged/basic cruiser vibe than all that leather. Waiting for mine and will post a pic back once I have them.
Does anyone have the part number for the black shifter bezel? My chrome one is starting to look like crap.
Never mind... 58843-60010
Champagne is definitely not a poverty item - or color. Repainted bumpers with a matte Rustoleum bumper and trim paint. Happy with the look. Just hope the paint holds up. View attachment 2473338View attachment 2473339View attachment 2473340
You need a black grill and delete the fog lights and remove the side mouldings to get a true poverty pack look also normally on those the mirrors will usually be matt black manual mirrors with chrome door handles and the chrome mouldings around the windows would be matt black with the shiny plastic part on the b pillar and around the top of the glass color matched to the rest of the door (in your case white)
