Here's the gage mount I incorporated into the 1HDT conversion on my FJ60. It is utilitarian, but I love it. Perfect for character of the truck.
Dan
Dan
That one appears to only do temperature sensors. The Auber unit does either pressure or temp sensors, has settings for alarms and trigger ouputs to relays for alarms. So you can use it to kick in a fan for extra cooling or shut off the engine if the pressure is too low.Those auber gauges are a good find, especially if they do EGT temp and boost on one gauge for around $80, I'm guessing your going to use it for EGT's, boost, oil psi and coolant? The only thing It seems to be lacking is display of what units, I suppose you will probably make some labels up.
Just looking at this four channel type K temp unit on ebay, about $40 but only displays one at a time, though i could check egt's intake temp pre/post IC, and coolant temp.
http://www.ebay.com/itm/Digital-DC-Temperature-Meter-for-4-Temp-Sensors-4-x-K-Type-Thermocouple-Inputs-/251315933518?pt=LH_DefaultDomain_2&hash=item3a8398d14e
I will be labeling them and yes I am using them for :
Coolant temp/oil pressure
Boost preaaure/EGTs
As for my truck, it can be found in my signature, under the non-project, project truck ...there are many pages, because there were many issues and complications, but recently if has gotten better.
Everyone screwing into the pillar, is there wires running up there and an internal steel skin to screw into? My 91 hdj80 gxl has fabric on the inside of the pillar.
Nice work!I went the sacrifice a vent route with my Glowshift 3in1.
Nice work!
