Maybe
THIS will help... There's more in this than you need for,your trailer, but you can see the wire runs you need, as well as the suggested wire gauge, etc.
You will need to run, from trailer tongue to lights and splice into that run to run marker lights. But, it's not a matter of simply stripping wire, twisting new wire on an taping it... There are various ways to make good splices... for example, you can cut the wire and a
3-WAY splice connector (crimp it or solder it).
They also sell the same splice connector, for
4-WAY... for your tail light run, you could run a tail light wire, from the connector (at the trailer tongue) to the back of your trailer.
- Cut this wire level with the first pair of marker lights
- Add a 4-way splice connector
- Splice the cut, using opposite sides of the 4-way
- Run one side to a marker light
- Run the other side to the other marker light
- Continue the run and cut the tail light run level with the next set of marker lights
- Continue the run and splice in a 3-way connector
- Run one leg to one tail light
- Run the other leg to the other tail light
You will also need wire runs for your stop lights and turn signals.
If you are running your wires in an area that is subject to getting wet, you'll need to figure out how to best waterproof your connections. It could be as simple as bringing the wire into the trailer, to make splices.
You could also use a bus bar or circuit breaker box, but that seems like overkill for the application you've described.
There are a lot of YouTube videos available that show how to splice wiring... Be sure you are looking at automotive or trailer wiring (12vdc), not house wiring... 12v is not nearly as hot and is much easier to properly splice.
HTH
