We were going up a hill @ 4K RPM in my 96 Land Cruiser, then a Pop noise, black poof of smoke out the tailpipe, then a complete stall. Prior to this issue, I had just changed the oil and oil filter (< 75 miles)
After I got it back home (thanks AAA for the tow) I found the Ignition Coil line had come off of the distributor, the lower EGR Vacuum hose was disconnected and the Vacuum Gas filter was cracked.
I replaced the Vacuum Gas Filter (this is located on the intake manifold).
Put hose clamps on the lower EGR vacuum line. It was not staying on.
Plugged the ignition coil line to the distributor.
I noticed the radiator was about 1/2 gallon low (seemed odd, I just checked it about 3 days prior)
The engine turned over without issue.
I checked the timing and it was dead on at 0-3 degrees.
MAIN Issue -
If the TLC is at idle I've run it up to ~2.5k RPM, it runs fine, but I notice a vapor drip out the tail pipe. I put it in gear and took it around the block. During the drive I notice a whispy noise and there is no acceleration after ~10 MPG, it just sputters but does not stall. After a quick trip around the block I notice the whispy noise might be coming from behind the exhaust heat shields, but not sure.
After the test I drained the new oil (<75 miles on it). Though the oil was quite dark in color, there did not appear to be any white, milky, or water to its appearance.
At this point I'm not quite sure what is wrong, any suggestions are most appreciated!
*Update*
FINAL Solution -- Replaced the CATS as they were plugged from the backfire
MAIN Issue -
*Update*
