alia176
Ok boys and girls, it's time to put on your thinking cap and solve this puzzle! A solution for this particular issue has been found but I think it's good exercise for y'all. Remember to pay close attention to Cause and Effect as you read the scenario.
Vehicle:
150k miles
Front DS splines cleaned out and regreased prior to this.
All original suspension bushings.
Symptoms:
1) when coming to a stop sharply, the Transmission shifter moves back and forth. The tip moves about 1/2".
2) you can recreate this isse by simply pressing and depressing the brake pedal while slowly moving forward. A distinct "clunk" is heard and is felt through the steering column.
3) while the "clunk" is being heard, you can look at the radius arm bushings and they're being compressed quite heavily. I'm referring to the bushings that sit directly behind the front axle on the control arm. The front bushings don't seem to have as much compression.
4) while off roading, you can watch the Transmission shifter move fore/aft as the suspension cycles over rough terrain.
Troubleshooting:
1) when driving with just the rear DS in the vehicle (CDL locked) you can really make the Transmission lever move back and forth. This is apparent while accelling hard or coming to a brisk stop.
2) when driving with just the front DS in the vehicle (CDL locked), all of these symptoms go away.
3) motor mounts are new
4) Tcase mounts don't "seem" sloppy but don't know for sure.
5) Drove home from Moab with both grease fittings removed from DS, no improvement.
Question:
What do you think is the problem?
Ali
Vehicle:
150k miles
Symptoms:
Troubleshooting:
Question:
Ali
