I really need some solid advice before I pull the trigger swapping out my wheels this week. I’m concerned my offset will effect my wheel bearings over time, gears, etc. My current setup just doesn’t work well. I’m hitting the KDSS and lower sway link bar at full turn and the gearing doesn’t like pushing around 101lbs per wheel/tire. I plan on making this my last LC for many years. I am looking for a happy medium of aesthetics,function and dependability. I understand offset and rotating weight can play a big part. Is the weight savings and offset difference going to make a big enough impact overall with my options below.
Current setup: (37lbs)18x9 Method +18offset on 35x12.50/r18 (KO2 64lbs)
OPTION 1: Keep wheels and replace tires with a 295/70/18 Cooper AT3 XLT weights 54lbs or 285/70/r18 Nitto RG weighs 60lbs-this size might look small(squared)on my method wheels with the bead locks ring pushing outward a little.
Option 2: 17x8.5 (27lbs) satin black ICON rebound +25 offset with either a 285/75/17 KO2 or 285/75/18 Nitto RG weighs 64.5lbs or 295/70/17 Cooper XLT weighs 58lbs(might be a bit to wide) and hit lower sway link bar and KDSS. They also make a 285/75/17. Similar weight
Current setup 35x12.50/r18 KO2
