Awl_TEQ
Supporting Vendor
I'm not a fan of aluminum or fiberglass. I fixed mine and helped supply @rkymtnflyfisher pieces to do his and they were both worse that that. 90% of what I can see there is the sill. You can see my thread here -> 81 BJ42 - I have to bring it home and pass inspection
You will do what you want of course but if that was mine I would brace the rear opening and cut out the rust one patch at a time and weld in steel. Leave it on the frame at least until you do the sill. Buy yerself a bit of 16ga steel and patch the quarters. Once the rust is gone you could blast it if you like, skim coat bondo where needed to and high fill primer and pick a color.
Patching a bit at a time will break it up into small 2-3 hour jobs and after a few weeks your son will be a welder and you can both stand back and admire the progress.
