I replaced the cruddy, worn out '555' brand pitman arm on my '94 22RE 4Runner with a cruddy Chinese 'DriveTech' pitman arm from Advance Auto. The splines on the new pitman arm were cut in a slightly different clocking than those on the previous arm. This means that after installing the arm, I cannot get the steering wheel to point straight ahead - I can have it off center one way or the other.
The truck does not need a wheel alignment, else, I'd let a shop fix this.
So, I installed the new pitman arm, pointed the truck wheels straight ahead, and then removed and reinstalled the steering wheel so that it was straight.
Is this the correct/best way do fix this problem? Unlike an FJ40, there is no drag-link adjuster sleeve that allows you to fix steering-wheel alignment while leaving the wheel alignment ok.
Thanks! - Steve
Thanks! - Steve
