Hello...I failed my NY inspection on my '78 fj40
for some stupid issues, my wife thinks the mechanic was jealous of my cruiser and the fine job I did in fixing it
2 of the reasons that I have a problem with are
#1
a cracked rear left spring
for the life of me I can't find a crack on the spring in the spot he says maybe he has x ray vision
#2
a bad pitman arm
again I don't see anything wrong with it
here's my questoin
how do I test a pitman arm for any defect?
there is a little play but there is no play in the steering at all .. very very thight in fact I was surprised after I drove it around for about 12 days that it is very very solid, stiff as it should be but it rides better than my exploder (less vibrations, an issue with older xploders)
I think a second opinion is required, on top of that the moron listed a lack of catalytic converter and no air pump... upstate NY emission is not tested, only safety I believe that '78 cruisers didn't come with one so unless the catalytic converter is a safety issue the guy must be on crack
anyone from NYS can confirm this.
thanks
BTW
there is also a leaking carburator but I knew that , I wasn't thinking it would be an issue other than for my wallet, the rebuild kit arrived today from summit so I should fix this in no time
#1
#2
a bad pitman arm
here's my questoin
thanks
BTW
