It seems that there are some weird nuances that changed for the rear heaters between the mid-70s and 1979. I’m looking for a pic of a 1977 rear heater from an original rig. Can someone post a pic from that year‘s rear heater specifically?
Yes, that shape and assembly is what I’m referring to. I have searched and found some [unconfirmed] subtle differences throughout the 70s.@cbmontgo are you referring to the shape of the top cover that protects the rear core and fan? I’m fairly sure that was unchanged through the mid 70s until 1/79 when it became more squarish and the color changed as well to more of a black. The mid 70s heater covers were slightly more “diamond” shaped with the holes at each side and they were pewter. I’ve seen unmolested 78s that still had the mid 70s style so I think your 77 would not be any different.
Note that FJ55 rear heaters have different outlets (as it were) on the top cover, and the motor protrudes from the bottom of the heater. If you try to bolt a '55 heater to an FJ40, it won't sit flat, due to this motor protrusion.
