Cryptic said:Besides the leaves being spaced apart from each other so they only contact at the spring pad and eyes, they seem to be the same idea as was used on domestic fullsize p/u's front suspensions. A half ton chev also has two leaves, full length, thick in center but tapered towards the ends. They are flat instead of arched though, 47" long with centered pins. Put some shims between them and they'd be great for a low buck low soa. I think fords front springs were longer so they'd be worth a look. One tons used three leaves as well.
Chef said:I I tested 2.5" lift, but they are also available in a lower 1" lift that is well suited for Spring Over Axle configuration.
Overlord said:How well do you think the 1" springs would hold up to a heavy SOA FJ60?
