Thumbed through the manual and didn't really see anything that stood out, so I figured y'all would know right off. On the drivers side of the rear diff:
Actually, that's the adjuster for the LSPV. Once it's set, it never moves, unless you modify the vehicle, after which you have to move it. It will continue to provide the input the valve needs from it, whether it's rusted or not.
The extra weight shouldn't be a problem, as it's within the design load capacity. The lift however, is another matter, and should be followed with a LSPV adjustment. (Comment to be followed by a litany of posts on why you should remove the LSPV, which I won't get into). Take a look at the procedure for replacing the LSPV in the FSM; the adjustment/qualification is in there.Thanks, I've just finished replacing rotors/calipers/brakes and it's time to bleed the system...having seen that the LSPV requires bleeding I was confused as to what it was...now I noz!
I am adding an OME 2.5" kit and plan on an ARB rear bumper, so maybe some adjustment in the future will be needed...
(even cheaper with ONSC membership; just saying...)
Yes, the valve will need to be bled. There is a bleeder screw on it for this purpose. IMO the LSPV is one of the trouble spots when bleeding your brakes, it can be difficult sometimes to get the air out of it.
You'll want to readjust it after the lift. When you disconnect the arm from the valve to the adjuster (if your LSPV isn't frozen) you will see how it operates. Where I live....we don't have rust issues, but the valve will develop a leak over time. Had to replace mine for just that reason.
Sometimes it takes a couple of weeks. Keep an eye on the clubhouse forum.Hey, I joined the second I saw ONSC existed!! Still haven't heard anything back tho'![]()
Holy boat anchors batman! IH8RUST!
