- Thread starter
- #21
The rear are about 4.5"
That’s backwards. Should work ok, but the slide part might suck water inside.rear drive shaft is in phase, but nipple is facing me on transfer case side and away from me on rear axle side...is that ok?View attachment 2532297
As I read the FSM this is correct orientation, but I think either direction works.That’s backwards. Should work ok, but the slide part might suck water inside.
You are right! I just installed mine backwards. But that’s how the front one is, slide is closer the axle.As I read the FSM this is correct orientation, but I think either direction works.
Repair manual shows the thinner end Front :The slide and seal go toward the transfer case....front and rear.
Those angles are way too off IMO. It looks like the shims are in backwards. The flanges need to be within a couple degrees to each other. The rear pinyon needs to be pointing upward and transfer case needs to point down. The front doesn’t need shims for drive angles but to keep the castor correct for steering. I had my pinyon angle incorrect and it rattled the bolts loose inside the case and blew a hole in that case. I’ll take a pic later of my setup and it is vibration free and smooth at all speeds. Spector has a diagram in there shim section if I remember correctly that shows proper shim position.
Take that shim out. It’s not needed
I never use them in the rear of any of my vehicles. I just use shims for caster on the front.
I thought you started with 2* then went to 4*
I would try it without them.
