Just replaced clutch and installed new OME Springs. also rebuilt front and rear wheel bearings.
I was having an issue with driveline vibration starting at 35mph so added a 4 degree shim which eliminated the vibration...but now I have a noise that sounds like its directly under 4WD shifter. It sounds like the gears aren't fully disengaged and the teeth are just barely touching...could be completely unrelated, but that is what it sounds like.
Its most noticeable at higher speeds when coasting in neutral or when clutch is engaged at above 35mph. I can occasionally hear it at lower speeds...but mostly when coming to a red-light or stop and shifting out of gear.
any ideas?
UPDATE IN POST 15 BELOW
any ideas?
