Good Info... Thanks!
BigCruizer said:So dumb question, Im thinking for now I want to put add a leafs on instead of a lift. Just doing this so I can get it back to normal hieght until I can afford a lift. So you can ut them on all four corners right? And if so, it wont change anything right? Thanks guys. Anthony
BigCruizer said:So if I were to just get the ome leaf packs instead, would it be worth it to just get the kit? What else would I need if I just got the springs? new shackles, possible shocks, ect?
cruiseroutfit said:At a minimum you will need new bushings and U-blots, shocks "could" wait (I don't recomend it unless they are long enough), and shackles & pins can be re-used if you are careful taking out the old ones. Hope that helps...
beaufort-fj60 said:so the factory shackles can be used with the OME.
sandcruiser said:Is it possible to move a 3rd leaf from the rear pack up to the front pack? ie: I've got heavy/heavy now and it is too heavy in back, not heavy enough up front (moved it from a gasser to a diesel).
So can I soften the rear and harden the front all at once? that would be great... but I don't want to pull stuff apart unless it will work
I have installed the Dakkar cs004f inthe front of my Hj61 but I am not happy with the result of the lift.
If I would order the extra leaf D1XL will it lift the front a bit and will it be more stiff.
Is the D1XL a flat or a arched leaf an in wich place of the spring pack it have to be installed.
thank you Kurt
do you ship to France?
