Nope, no leakage.
Then why do you think the light would go on? I ask because this is EXACTLY what has happened with mine. Same make and weight oil, same result.
Nope, no leakage.
Dudes...I've never seen the light. I've never had to add oil between changes. If I saw the light, I would check the level. This motor has tons of reserve. Keep it topped off and don't worry about it.
Keep a quart in your 80, mine does that periodically, if I' away from the house, I'll check it and add some if needed. I've noticed over the past year that my 80 likes oil. I have no leaks.
Now my VW TDI.. ya.. the low oil light comes on about 30 seconds before you start sucking air off the bottom of the oil pan.... Nice.
I got my oil changed Friday. And yes, it's topped off.
The oil light came on today while driving. Lets just say that my oil light is *VERY* sensitive.
Now the truck comes on at darn near exactly a quart low.
I'm half tempted to just pull the bulb since it's on so much. I should probably replace the sensor, but it doesn't look particularly simple....
Mine has never come on, even when a little low. I just check it once every other fill up. About once every other week. I don't ever need to top it off till about three hundred miles before my oil change is up again. Then I'm about 1/2 a quart low. I'm amazed at how little oil this thing goes through.
Edit: I guess it does come on, but only on first start up after my oil change. At least I know it works.
I'm not sure 3FE's even have a "low oil level" sensor/light; just a low/no oil pressure
sensor/light.
Well, I believe its just below the oil pressure guage. CAn't remember for sure since it only came on three thousand miles ago when I started up after my oil change for the first time. It stays lit for about two to three seconds, then it goes off as pressure climbs to normal.
Nice to see a actual picture of the unit. Had similar issue about 12 years ago. After taking to dealer while being on Trip to Sequoia then Sacramento the light came on going down the long incline to the desert from ST George. Checked oil and level okay. Had dealer look at in Sacramento and they indicated oil pressure switch. Purchased new one and installed with minimal tools at Moms house. Luckily 1/2" is same as 13MM.To revive an old thread...I’ve had my oil light come on and off intermittently. It seems to come on more when the engine is warm. It also seems to go on and off going over bumps. I was thinking it was dirty, so I pulled the sensor and cleaned it. While cleaning it, there was one little collar part that looked broken (see picture). I put it back in with a new gasket and changed the oil (you don’t need the oil pan drained to pull the sensor). Light still comes on and off (UGH). My thought is that little broken collar piece on that small disc just above the main float is just enough to hang up the main float so it doesn’t go up easily and gets stuck (maybe that disc isn’t supposed to separate from the main float)? Also, when the oil is warm it is moves easier with bumps on rough roads, so it gets separated and hangs up then the light goes on and off with bumps. I’m thinking about trimming that collar or just removing that top disc? Anyone have any thoughtS or experience with this? (Trying to avoid the pmcost of a new sensor).
Well light came back in WY coming back. Took our mechanic, Toyota OEM only, independent. They diagnosed it as this switch. The float had a crack and would fill up with oil and send a warning light.
Long story short, instead of 260$ plus labor, they offered to zip tie. Has worked with out coming on ever since.
I believe the 97 FZJ80 has all the bells and whistles including this oil level indicator. Now at 286K new head gasket a year ago and burning oil I just make sure to check the oil level. Old school. Still search for part but at 260$ many other things to fix and maintain. Still have the original working oil sender unit.
A good quality zip tie should last. Our has been in for over 15 years. Good luck with trimming the disc.Thanks for the reply...zip tie maybe a good option? I would worry it would get heated enough over time that could break and end up in the oil pan? I guess, it is unlikely to get past the filter if it did break and end up draining with the next oil change? I may try to trim that disc first...zip tie it up as option #2.
