View attachment 1203192 brand new OEM or are the replacement torx screws good enough?? I'm concerned the Replacments are slightly too short for positive hook up. I don't believe it was leaking before but it is impossible to tell with the main seal leaking so badly. Thoughts???
View attachment 1203795 So four threads on the hex screws make it past the cover. Seven threads make it past the cover on the OEM fastener. @Hornd are the fasteners you're distributing the same length as the OEM? As of right now I'm going to go back to the OEM after seeing this.
