Dan Edmunds back with the good stuff (forgive his model nomenclature misspeak):
Toyota Land Cruiser vs Lexus LX 570 Suspension Flex Test | Measuring suspension articulation on an RTI ramp - Autoblog
We compare the Toyota Land Cruiser and its Lexus LX 570 on an RTI ramp, which measures suspension articulation.www.autoblog.com
Has anyone on here heard a clicking sound coming from the rear when navigating rocky terrain off road? Nothing visible and I have removed the highlift thinking that was it. Stumped! Thanks for your input, L.
Crawl control?
This isn't it. I'm talking more about simply cruising down a corrugated or rocky forest road.
How loud and how consistent is it? First thought would be a rock stuck in the voids of the tread, but could potentially be a lot of things. What year is your 200 and what mods does it have? How many miles could be relevant due to wear items too.
Double check the top nut on the rear shocks?
Yup, the first place too ck after the hi-lift.
After you check that the top shock nut is secure, try grabbing the upper part of the shock and give it a twist. There should be enough pressure on the upper mount assembly to keep it from moving around. You may have the dreaded "clunk". The rubber bushings used in the upper mount may not be firm enough to keep the hat washer in place and is allowing the stack to jump in and out of its mount on the frame. Its an easy fix by adding another washer to the top of the stack to increase pressure on the rubber bushings. Its best to use an old shock washer with a hole diameter large enough to slip on to the main shock shaft, not just the threaded portion. The nut needs to bottom out at the end of the threaded portion.
OME sent me a bunch of new rubber bushings but I found that just adding another washer fixed the problem even with the new bushings. If this is the problem, you will want to get to it before the shock hat washer augers out the frame mount.
why does my CDL enjoy flashing when the weather is hot and not when it's cold like the rest of the 200s that have this issue occasionally.
