Well with the cruiser torn apart and waiting on several parts to finish up various projects. I decided to start one more project and follow up on a post from when I first bought the cruiser. Although not horribly bad I can tell the charcoal canister is clogged and intermittently causing to much pressure to build up in the tank. The most chosen option is a variation of a General Motors canister from your favorite neighborhood auto parts store. However I wanted an OEM replacement due to smog issues here in California and the fact that I'm not fond of zip tying Pontiac parts to my cruiser (Yes, Pontiac Aztecs are the s***). @hoser Suggested that possibly a FZJ100/FZJ105 canister could work since the original is NLA. I ended up finding a FZJ105 (1FZ in a 100 series body) canister in Dubai for $154.25 on Ebay. The part number is 77704-60290, there is also a similar canister available 77740-60400 which is for a UZJ100.
The canisters are of similar size, the new canister is slightly shorter due to the flat bottom. It is also a little bit wider and has more girth.
The retro fit will require 3 modifications:
1. I will need slightly longer bolts than OEM for the additional girth.
2. I will need to shave off the laminated on plastic 100 series mount, to use both factory mounting loops.
3. I will need to extend the bottom breather, as the new canister does not have a factory extension on it.
*I am also using new clamps as the purge nipple diameter is smaller than the original hose.
Toyota Genuine 77704-60290 Canister Sub-Assy Charcoal 7770460290 OEM | eBay
We are happy to take care of all your Genuine parts and accessory needs. We specialize in Japanese Auto Spare Parts: Toyota / Lexus, Nissan / Infiniti, Mitsubishi, Mazda, Subaru, Suzuki. Genuine OEM Parts.
www.ebay.com
