OEM Brake Caliper Clarification Needed (Loaded vs. Unloaded)
Bright Zinc plated (silver)
Mine are silver as well. Came with all new bolts and fittings. Just drop in pads and bolt on.
Description:Disc Brake Caliper (Right, Front)
Part Number: 4773060061
Quantity:1
Price:$153.28
Description:Disc Brake Caliper (Right, Rear)
Part Number: 4773060110
Quantity:1
Price:$154.79
Description:Disc Brake Caliper (Left)
Part Number: 4775060061
Quantity:1
Price:$153.28
Description:Disc Brake Caliper (Left, Rear)
Part Number: 4775060110
Quantity:1
Price:$154.79
Great feedback, thanks!
For the record, my new front calipers came with the seals and pistons as well as the pins, clip and bleed screw. The finish was bright aluminum. I installed them as-is. The rears were the same bright aluminum finish with the seals, pistons and bleed screw included. I only had to add pads and associated retainer and wear clips along with new banjo bolts and copper washers.
Hi. Do you have the part numbers for the associated retainer and wear clips along with new banjo bolts and copper washers? I am replacing my front calipers with OEM. Thanks!
I think the banjo bolt is same all around and it is 90401-10015.
Great decision, here you go. Quantities are for the whole truck, divide in half for each axle.
High Pressure Banjo Bolts (Qty. 4):
90401-10015
High Pressure Copper Washers (Qty. 8):
90430-10074
Spring Clip Retainer (Qty. 4)
90468-12015
Shim Kits - Anti-Squeal (Qty. 1):
Front - 04945-04012
Rear - 04946-60010
Fitting Kits - Wear Indicators (Qty. 1):
Front - 04947-60090
Rear - 04947-22050
90401-10015
90430-10074
90468-12015
Front - 04945-04012
Rear - 04946-60010
Front - 04947-60090
Rear - 04947-22050
Thank you!
