Been battling an issue for a week or two now:
1. Battery intermittently working. A couple times now we’ve gone out to the truck and it was either dead or battery was very weak.
2. 2x now in the last week the truck has completely lost power (as in shut off completely) when going around a corner. Restarting works fine and continue as normal.
No codes, no battery/charge lights. Voltage reads 14V when the truck is running. Battery seems to lose charge over time so I’m thinking bad battery. Took it in and the guy said it looks weak but not bad. He thinks its been charging poorly. Alternator is a factory reman Denso unit That was installed ~3 years ago and its putting out 14V so I don’t think that’s the issue.
So what am I looking at here, a bad ground? I would say parasitic drain but all electrics are stock and the battery issues are intermittent. Truck is fine for a week or so then has an issue. I took apart the fusable link box behind the battery (on the positive post) and it looks normal and not corroded. Where else should I be looking?
