SmokingRocks
hopelessly addicted to Cruisers
Recently I've noticed an interesting issue that seems to randomly happen in the morning when the rig is cold.
When setting off for the first time I'll roll about 30% into the throttle and the rig is SLOW to accelerate. So I add more throttle and the power comes on like a light switch. It seems to only happen once then it's fine.
No codes.
It hasn't become such a major issue that I've needed to put the rig out of service to figure it out, so I'm casually troubleshooting what the issue could be. My first thought is the fuel pump relay is not working right, since it feels like the engine is only giving up to 50% power, then press further into the gas pedal and BAM 100% of power becomes available.
But since this only happens once and it's fine for the rest of the day I'm thinking it's not the FPR (also the FRP is less than 2 years old), but perhaps the signal it's getting. And if that's the case then what's the real cause? The ECU? or one of the sensors that it's monitoring like the throttle position sensor?
Anyway, I just wanted to float this out there and see if anyone has experienced this before. I guess my next step is to wire up a voltmeter to Port 1 of the Data Link Connector (fuel pump +) to see if that's the system having an issue.
I've also had a very loopy idle randomly if I let the rig idle for more than a min or two once warmed up, but I think this was an EGR issue and since I've disabled it I haven't experienced it again. Idle is super lumpy when cold, very similar to a major vacuum leak
No codes.
