Very useful chart for this issue
That's not the correct switch for what you need. you will need his one here, I just replaced mine last month.
PN:
84140-12260
Panda - Can you elaborate on how you replaced this? I'm having the same issue. Did you have to remove the steering wheel, etc. as outlined in the thread previously? Thanks!
Mine (94) only had high when held. Drove that way 6 mos and needed the highs . I disassembled hi/lo switch quickie clean and relubed. been 2+ years and not skipped a beatThought I would chime in. I has having the same issue on my 1993 HDJ80. Turned out to just be the dimmer relay. I addressed all of the contact points and ground connections to no avail... swapped the dimmer relay and everything works great!
Would you mind sharing more about the process to disassemble and clean the switch? I feel like I'm having the same issue but do not know where to begin. Thanks!Mine (94) only had high when held. Drove that way 6 mos and needed the highs . I disassembled hi/lo switch quickie clean and relubed. been 2+ years and not skipped a beat
There is only one relay in the headlight system that feeds +12 through the left/right fuses. This feeds +12 to all 4 bulbs when the stalk switch is on. Low beams are grounded directly to each fender, high beams are grounded through the stalk switch.Do the late models use the same switch? My 95 is doing this now except that my high beams come only on dimly when the switch is pushed forward and brightly when the switch is held back. (LED bulbs.)
Switch? Relay? Both? Any other ideas?
Not very likely. 1 relay feeds both low and high.Recently had the same thing happen to my 96 model FZJ80. Noticed first that the high beams would not come on immediately (stalk pushed forward) with cold outside air temps, but if I left the stalk in the forward position the high beams would come on after a few seconds or so.
This delay (high beams not coming on with the stalk forward) got worse over a few weeks to the point that the high beams would rarely come on with the stalk forward (but always would work when pulling the stalk rearward for flash).
So just for grins I swapped in a known good headlamp relay from another 80 and the issue went away. The high beams now come on immediately every time with the stalk pushed forward.
So weak relay maybe??
That's not exactly the way it works, but you're very close.I had a similar delay-on situation for a while before my own high beams finally quit. According to the FSM there is only one headlight relay but there is also something called a 'headlight retainer circuit' box that looks like another relay but it has 7 terminals. No idea what it does or how it works, have to look that up in the EWD manual. Since I have to check some wire colors in the EWD to dig into my problem I'll check it out and report back. Unless someone knows off the top of their head?
EDIT- Well it appears in the EWD on page 70 that the difference between normal high beam operation and the flash operation is activating terminal #14 in the main connector, which feeds power through the retainer circuit relay and back around into the same ground for the low beams. Which should mean that if either of the the relays were not working properly that the high beams would not work at all. So the most likely problem is a bad switch. I probably hurt mine with a mistake in my plow light wiring.
Can't imagine why my switch would go bad after a mere 26 hard years of snow, ice, dust, dirt, water, bad wiring mods, and corrosion, but there it is.
After cleaning them up and bending them out it all works fine. Don't know for how long though.This here was the issue
The tabs had worn down so far that they where not connecting properly.
Even after pulling it apart I'm not sure how one could do it without making a mess.
